March 11, 2023 at 2:58 am
Satyam Sa
SubscriberHi everyone,
I am trying to simulate high frequency transformer using external excitation, after successfully updating and importing the external circuit netlist, analyze for the transient simulation gives the following error as shown in the figure below. I am unsure how to resolve this issue, any help is appreciated.
Thanks & Regards
Satyam -
March 14, 2023 at 6:10 am
muriloendres
SubscriberI am facing similar error as mentioned above, by Satyam.
I am importing csv-data to Maxwell-Circuit and creating an .sph file. The .sph is imported to Maxwell2D. This method is working for me in some cases. For example, if the imported circuit has a Piecewise-Linear Voltage element, there is no error and the simulations are working. However, if the circuit has Piecewise-Linear current element, I am getting the error message given below.
[error] Maxwell2d solver, process solver2d error: Internal Solver Error: ‘Cannot open file: extnlckt.par!’. Please contact Ansys technical support.
[error] Simulation completed with execution error on server: Local Machine.
- Maxwell, HFSS or Q3D?
- Error
3670
2550
1749
1226
582
