Discovery Import
Discovery Import
Error in Refine Mode: job submission failed
    • klara.marek
        Hello, I am trying to run a simulation as depicted above. The picture shows the fluid domain (air). I did not have problems running the simulation in Explore Mode and also no problems when starting the simulation with the two parts of the fluid domain separated (the box and the part with the tubes). However this results in a faulty mesh with big cells in the box and smaller cells in the other part, resulting in incorrect results. Therefore I combined them to form one volume on which the meshing and simulation shoul be performed. Where can I find the Inner Submission Result Property to find out more details about this porblem? Or is there a mistake in my approach? Thank you very much for all comments, clarifications and inputs regarding this problem!
    • Charudatta Bandgar
      Hello Klara ,
      Can you please send the files, I will need to look into it and see what the issue could be, I have sent the secure transfer link.
      Regards.
      Hello Klara ,
      The error you are getting is due to a bug in the solver, but I am not sure and hence I am cross verifying on my end. Based on your explanation, I think the way you have done isn't wrong in the way it is setup.
      Regards.
      Hello Klara , When I write out your file as Parasolid and do the setup from scratch I am able to solve the run in refine mode. It looks like, while you were combining (or due to some other reason), the file got corrupted. I have sent you the files through secure transfer. Regards.
    • klara.marek
      Hello Charudatta Bandgar
      thank you for looking into this problem and finding a solution! However it seems like I haven't received the files through secure transfer.
        I have sent the files, please check and let me know, Klara
        Regards.
      • klara.marek
        Charudatta Bandgar I have just received the transfer link and could open and run the simulation - thank you very much!
    • m.camposaragna
      Charudatta Bandgar we have found the same error in a structural simulation. The original geometry file is an .scdoc. There's a workaround different from start from scratch: Customer will not be happy.....
        Michele Camposaragna Hello
        Will it be possible for you to send the files over?
        Regards.
      • m.camposaragna
        Charudatta Bandgar Of course. On which platform?
Viewing 5 reply threads
