Discovery Import
Discovery Import
Error in refine mode
    • hyun-sung.kwon
      Hello, I have very simple setup to see  a mixing behavior with different temperature. I don't have any issue in the explore mode to run simulation. but the simulation stops in the refine mode. It just said 'an error has occurred while solving. Review the physics setup'.  but I don't see nothing particular in the setup. Please advice where I should look to solve this issue - the condition set up is very simple as you see below. - FYI. this Simulation option. Thanks in advance.
    • Charudatta Bandgar
      Hello HYUNSUNG KWON
      The setup does look correct, I will have to try it on my end to see what the issue could be. Will you be able to share the run files with me? If you want I can share a secure transfer link for you to upload the files.
      Regards.
