Error in the Discrete Phase Histogram plot of Mass Flow Rate
    • Raj007
      Hello Everyone,
      I have a model with Multiple inlets and Outlets. I wanted to plot the Mass Distribution of Outlets in Histogram. But when I was loading the file in the Trajectory Sample Histograms.
      It was showing some error like "Reading sample file...
      Read_Sample_Section: error reading history header from the file, giving up."
      I also want to tell you that by default it was asking for .dpm format. But, I have the .out format. I hope this is not a problem.
      Please help or suggest any answer.
      Thank you
      Raj
    • Keyur Kanade
      do you want like
      outlet1 - mass flow
      outlet2 - mass flow etc.
      you may want to use xy plot.
      you can also try excel.
      Keyur
    • Raj007
      I have around 147 outlets. I have given a single named selection for all the outlets like I have selected 147 outlets and named it as "Outlets".
      I want to check each outlet mass flow and compare them. But, the fluent is giving me the sum of all outlets.
      I hope you got my point, please let me know if you need any other info for helping me.
      Thank you
      Raj
      It will, you need separate labels for each surface. I assume you're using pressure outlets?
    • Raj007
      Yeah, I have pressure-outlets. But, I want to know, is it possible to do without giving individual names.
      I just want to skip to do it again.
      Please let me know if it is possible?
      I am only concerned with individual values of mass flow, even the histograms can be excluded. If we have a any other possible solutions.
      Thank you
      Raj
    • Keyur Kanade
      you will have to separate.
      you can use domain - separate option in fluent.
      Keyur
Viewing 5 reply threads
