October 7, 2021 at 4:31 pm
cs437
SubscriberHi,
The following error is what I got from my simulation run from the HPC cluster.
Error: = (equal): invalid argument [1]: wrong type [not a number]
Error Object: #f
;Do 100000 iterations
it 100000
I am not sure whether it is because of the Fluent version. The setup was created using ANSYS Fluent 2021 R2; however, HPC is ANSYS v.20.1. I typically use the following code to run my simulations and it had been working well. Please suggest if the command needs to be updated.
; Read the CASE File
rc /home/c/cs437/500ml/20-500-100/20-500-100.cas.h5
rd /home/c/cs437/500ml/20-500-100/20-500-100.dat.h5
it 100000
;Write output back to data file
wd 201-500-100.dat.gz
;exit Fluent
exit
yes
October 14, 2021 at 7:44 pmKarthik R
AdministratorHello Can you add a command to your journal file to ask Fluent to start writing the transcript?
file start-transcript
Hopefully, the transcript file will tell you where the issue is.
Karthik
March 14, 2022 at 12:36 pmgmteke
SubscriberHello Is there a solution to this problem? Please, thanks.
Thanks
George
2688
2138
1355
1136
462
