Discovery Import
Discovery Import
Error in thread depth dimension
    • mu
      adding a thread to a hole whose surface is interrupted by a machining the thread depth dimension doesn't start from the starting edge of the thread, but from the point where the hole surface is whole. Why the depth doesn't start from the starting edge pf the thread?
      Is there a way to redefine the starting point for thread depth dimension?
      Thank you in advance,
      Marco
    • Subashni Ravichandran
      Hello Marco Ugolotti
      Let me look into this and get back to you.
      I have filed a bug for this issue.
