March 20, 2023 at 5:37 pm
Francesc Riera
SubscriberHi, I'm following online tutorials to simulate a Two-Way FSI but when I get to system coupuling I allways get the same errors. There is a photo of the error messages and the solution infformation of the system coupling.
This file may contain appended logs from a sequence of runs, with the mostrecent output reported at the end of the file.===============================================================================Transcript output started: 2023-03-20 17:59:24===============================================================================+=============================================================================+| || Summary of Coupling Setup || |+=============================================================================+===============================================================================+=============================================================================+| Coupling Participants (2) |+=============================================================================+| || Participant: Fluid Flow (Fluent) || Type : FLUENT || UpdateControls: || Option : ProgramControlled || Region: fluid-solid_interface || Topology : Surface || Input Variables : displacement || Output Variables : force || Variable: displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || Variable: force || Quantity Type : Force || Location : Element || Tensor Type : Vector || Is Extensive : True || Data Type : Real || |+-----------------------------------------------------------------------------+| || Participant: Static Structural || Type : MAPDL || UpdateControls: || Option : ProgramControlled || Region: Fluid Solid Interface || Topology : Surface || Input Variables : Force, Force_Density || Output Variables : Incremental_Displacement || Variable: Force || Quantity Type : Force || Location : Node || Tensor Type : Vector || Is Extensive : True || Data Type : Real || Variable: Incremental_Displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || |+=============================================================================+| Analysis Control |+=============================================================================+| || Analysis Type : Steady || Global Stabilization : None || OptimizeIfOneWay : False || AllowSimultaneousUpdate : False || PartitioningAlgorithm : SharedAllocateMachines || |+=============================================================================+| Coupling Interfaces (1) |+=============================================================================+| || Interface: interface-1 || Side: One || Coupling Participant : Static Structural || Region List : Fluid Solid Interface || Reference Frame : GlobalReferenceFrame || Side: Two || Coupling Participant : Fluid Flow (Fluent) || Region List : fluid-solid_interface || Reference Frame : GlobalReferenceFrame || Data Transfer: Data Transfer || Suppress : False || Target Side : Two || Source Variable : Incremental_Displacement || Target Variable : displacement || Unmapped Value Option : Nearest Value || Mapping Type : Surface Profile Preserving || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Data Transfer: Data Transfer 2 || Suppress : False || Target Side : One || Source Variable : force || Target Variable : Force || Mapping Type : Surface Conservative || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Mapping Control: || Absolute Gap Tolerance : 0.0 [m] || Face Alignment : ProgramControlled || Poor Intersection Threshold : 5.00e-01 || Relative Gap Tolerance : 1.00e+00 || Stop If Poor Intersection : True || |+=============================================================================+| Solution Control |+=============================================================================+| || Duration Option : NumberOfSteps || Maximum Iterations : 2 || Minimum Iterations : 1 || Number Of Steps : 80 || |+=============================================================================+| Output Control |+=============================================================================+| || Output Control Option : LastStep || Results || IncludeInstances : ProgramControlled || Option : Off || Write Initial Snapshot : True || |+=============================================================================++-----------------------------------------------------------------------------+| Warnings were found during data model validation. |+-----------------------------------------------------------------------------+| Warning: Participant Static Structural (CouplingParticipant:Solution) has || the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. || Warning: Participant Fluid Flow (Fluent) (CouplingParticipant:Solution 1) || has the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. |+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent || participants are set to 'Element'. Make sure that this is consistent with || the setup within Fluent. When importing the SCI file (this includes running || inside Workbench), you can control the locations of these variables by || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more || information, refer to System Coupling User's Guide. |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...+-----------------------------------------------------------------------------+| "System coupling solution stopped before all participants connected. A || solver failure occurred during the run in the Fluid Flow (Fluent) system" |+-----------------------------------------------------------------------------+Transcript output stopped: 2023-03-20 17:59:44==============================================================================================================================================================Transcript output started: 2023-03-20 18:02:41===============================================================================+=============================================================================+| || Summary of Coupling Setup || |+=============================================================================+===============================================================================+=============================================================================+| Coupling Participants (2) |+=============================================================================+| || Participant: Fluid Flow (Fluent) || Type : FLUENT || UpdateControls: || Option : ProgramControlled || Region: fluid-solid_interface || Topology : Surface || Input Variables : displacement || Output Variables : force || Variable: displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || Variable: force || Quantity Type : Force || Location : Element || Tensor Type : Vector || Is Extensive : True || Data Type : Real || |+-----------------------------------------------------------------------------+| || Participant: Static Structural || Type : MAPDL || UpdateControls: || Option : ProgramControlled || Region: Fluid Solid Interface || Topology : Surface || Input Variables : Force, Force_Density || Output Variables : Incremental_Displacement || Variable: Force || Quantity Type : Force || Location : Node || Tensor Type : Vector || Is Extensive : True || Data Type : Real || Variable: Incremental_Displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || |+=============================================================================+| Analysis Control |+=============================================================================+| || Analysis Type : Steady || Global Stabilization : None || OptimizeIfOneWay : False || AllowSimultaneousUpdate : False || PartitioningAlgorithm : SharedAllocateMachines || |+=============================================================================+| Coupling Interfaces (1) |+=============================================================================+| || Interface: interface-1 || Side: One || Coupling Participant : Static Structural || Region List : Fluid Solid Interface || Reference Frame : GlobalReferenceFrame || Side: Two || Coupling Participant : Fluid Flow (Fluent) || Region List : fluid-solid_interface || Reference Frame : GlobalReferenceFrame || Data Transfer: Data Transfer || Suppress : False || Target Side : Two || Source Variable : Incremental_Displacement || Target Variable : displacement || Unmapped Value Option : Nearest Value || Mapping Type : Surface Profile Preserving || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Data Transfer: Data Transfer 2 || Suppress : False || Target Side : One || Source Variable : force || Target Variable : Force || Mapping Type : Surface Conservative || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Mapping Control: || Absolute Gap Tolerance : 0.0 [m] || Face Alignment : ProgramControlled || Poor Intersection Threshold : 5.00e-01 || Relative Gap Tolerance : 1.00e+00 || Stop If Poor Intersection : True || |+=============================================================================+| Solution Control |+=============================================================================+| || Duration Option : NumberOfSteps || Maximum Iterations : 2 || Minimum Iterations : 1 || Number Of Steps : 80 || |+=============================================================================+| Output Control |+=============================================================================+| || Output Control Option : LastStep || Results || IncludeInstances : ProgramControlled || Option : Off || Write Initial Snapshot : True || |+=============================================================================++-----------------------------------------------------------------------------+| Warnings were found during data model validation. |+-----------------------------------------------------------------------------+| Warning: Participant Static Structural (CouplingParticipant:Solution) has || the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. || Warning: Participant Fluid Flow (Fluent) (CouplingParticipant:Solution 1) || has the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. |+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent || participants are set to 'Element'. Make sure that this is consistent with || the setup within Fluent. When importing the SCI file (this includes running || inside Workbench), you can control the locations of these variables by || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more || information, refer to System Coupling User's Guide. |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...+-----------------------------------------------------------------------------+| "System coupling solution stopped before all participants connected. A || solver failure occurred during the run in the Fluid Flow (Fluent) system" |+-----------------------------------------------------------------------------+Transcript output stopped: 2023-03-20 18:03:01==============================================================================================================================================================Transcript output started: 2023-03-20 18:04:07===============================================================================+=============================================================================+| || Summary of Coupling Setup || |+=============================================================================+===============================================================================+=============================================================================+| Coupling Participants (2) |+=============================================================================+| || Participant: Fluid Flow (Fluent) || Type : FLUENT || UpdateControls: || Option : ProgramControlled || Region: fluid-solid_interface || Topology : Surface || Input Variables : displacement || Output Variables : force || Variable: displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || Variable: force || Quantity Type : Force || Location : Element || Tensor Type : Vector || Is Extensive : True || Data Type : Real || |+-----------------------------------------------------------------------------+| || Participant: Static Structural || Type : MAPDL || UpdateControls: || Option : ProgramControlled || Region: System Coupling Region || Topology : Surface || Input Variables : Force, Force_Density || Output Variables : Incremental_Displacement || Variable: Force || Quantity Type : Force || Location : Node || Tensor Type : Vector || Is Extensive : True || Data Type : Real || Variable: Incremental_Displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || |+=============================================================================+| Analysis Control |+=============================================================================+| || Analysis Type : Steady || Global Stabilization : None || OptimizeIfOneWay : False || AllowSimultaneousUpdate : False || PartitioningAlgorithm : SharedAllocateMachines || |+=============================================================================+| Coupling Interfaces (1) |+=============================================================================+| || Interface: interface-1 || Side: One || Coupling Participant : Fluid Flow (Fluent) || Region List : fluid-solid_interface || Reference Frame : GlobalReferenceFrame || Side: Two || Coupling Participant : Static Structural || Region List : System Coupling Region || Reference Frame : GlobalReferenceFrame || Data Transfer: Data Transfer || Suppress : False || Target Side : Two || Source Variable : force || Target Variable : Force || Mapping Type : Surface Conservative || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Data Transfer: Data Transfer 2 || Suppress : False || Target Side : One || Source Variable : Incremental_Displacement || Target Variable : displacement || Unmapped Value Option : Nearest Value || Mapping Type : Surface Profile Preserving || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Mapping Control: || Absolute Gap Tolerance : 0.0 [m] || Face Alignment : ProgramControlled || Poor Intersection Threshold : 5.00e-01 || Relative Gap Tolerance : 1.00e+00 || Stop If Poor Intersection : True || |+=============================================================================+| Solution Control |+=============================================================================+| || Duration Option : NumberOfSteps || Maximum Iterations : 2 || Minimum Iterations : 1 || Number Of Steps : 80 || |+=============================================================================+| Output Control |+=============================================================================+| || Output Control Option : LastStep || Results || IncludeInstances : ProgramControlled || Option : Off || Write Initial Snapshot : True || |+=============================================================================++-----------------------------------------------------------------------------+| Warnings were found during data model validation. |+-----------------------------------------------------------------------------+| Warning: Participant Static Structural (CouplingParticipant:Solution) has || the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. || Warning: Participant Fluid Flow (Fluent) (CouplingParticipant:Solution 1) || has the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. |+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent || participants are set to 'Element'. Make sure that this is consistent with || the setup within Fluent. When importing the SCI file (this includes running || inside Workbench), you can control the locations of these variables by || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more || information, refer to System Coupling User's Guide. |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...+-----------------------------------------------------------------------------+| "System coupling solution stopped before all participants connected. A || solver failure occurred during the run in the Fluid Flow (Fluent) system" |+-----------------------------------------------------------------------------+Transcript output stopped: 2023-03-20 18:04:27===============================================================================This file may contain appended logs from a sequence of runs, with the mostrecent output reported at the end of the file.===============================================================================Transcript output started: 2023-03-20 17:59:24===============================================================================+=============================================================================+| || Summary of Coupling Setup || |+=============================================================================+===============================================================================+=============================================================================+| Coupling Participants (2) |+=============================================================================+| || Participant: Fluid Flow (Fluent) || Type : FLUENT || UpdateControls: || Option : ProgramControlled || Region: fluid-solid_interface || Topology : Surface || Input Variables : displacement || Output Variables : force || Variable: displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || Variable: force || Quantity Type : Force || Location : Element || Tensor Type : Vector || Is Extensive : True || Data Type : Real || |+-----------------------------------------------------------------------------+| || Participant: Static Structural || Type : MAPDL || UpdateControls: || Option : ProgramControlled || Region: Fluid Solid Interface || Topology : Surface || Input Variables : Force, Force_Density || Output Variables : Incremental_Displacement || Variable: Force || Quantity Type : Force || Location : Node || Tensor Type : Vector || Is Extensive : True || Data Type : Real || Variable: Incremental_Displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || |+=============================================================================+| Analysis Control |+=============================================================================+| || Analysis Type : Steady || Global Stabilization : None || OptimizeIfOneWay : False || AllowSimultaneousUpdate : False || PartitioningAlgorithm : SharedAllocateMachines || |+=============================================================================+| Coupling Interfaces (1) |+=============================================================================+| || Interface: interface-1 || Side: One || Coupling Participant : Static Structural || Region List : Fluid Solid Interface || Reference Frame : GlobalReferenceFrame || Side: Two || Coupling Participant : Fluid Flow (Fluent) || Region List : fluid-solid_interface || Reference Frame : GlobalReferenceFrame || Data Transfer: Data Transfer || Suppress : False || Target Side : Two || Source Variable : Incremental_Displacement || Target Variable : displacement || Unmapped Value Option : Nearest Value || Mapping Type : Surface Profile Preserving || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Data Transfer: Data Transfer 2 || Suppress : False || Target Side : One || Source Variable : force || Target Variable : Force || Mapping Type : Surface Conservative || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Mapping Control: || Absolute Gap Tolerance : 0.0 [m] || Face Alignment : ProgramControlled || Poor Intersection Threshold : 5.00e-01 || Relative Gap Tolerance : 1.00e+00 || Stop If Poor Intersection : True || |+=============================================================================+| Solution Control |+=============================================================================+| || Duration Option : NumberOfSteps || Maximum Iterations : 2 || Minimum Iterations : 1 || Number Of Steps : 80 || |+=============================================================================+| Output Control |+=============================================================================+| || Output Control Option : LastStep || Results || IncludeInstances : ProgramControlled || Option : Off || Write Initial Snapshot : True || |+=============================================================================++-----------------------------------------------------------------------------+| Warnings were found during data model validation. |+-----------------------------------------------------------------------------+| Warning: Participant Static Structural (CouplingParticipant:Solution) has || the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. || Warning: Participant Fluid Flow (Fluent) (CouplingParticipant:Solution 1) || has the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. |+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent || participants are set to 'Element'. Make sure that this is consistent with || the setup within Fluent. When importing the SCI file (this includes running || inside Workbench), you can control the locations of these variables by || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more || information, refer to System Coupling User's Guide. |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...+-----------------------------------------------------------------------------+| "System coupling solution stopped before all participants connected. A || solver failure occurred during the run in the Fluid Flow (Fluent) system" |+-----------------------------------------------------------------------------+Transcript output stopped: 2023-03-20 17:59:44==============================================================================================================================================================Transcript output started: 2023-03-20 18:02:41===============================================================================+=============================================================================+| || Summary of Coupling Setup || |+=============================================================================+===============================================================================+=============================================================================+| Coupling Participants (2) |+=============================================================================+| || Participant: Fluid Flow (Fluent) || Type : FLUENT || UpdateControls: || Option : ProgramControlled || Region: fluid-solid_interface || Topology : Surface || Input Variables : displacement || Output Variables : force || Variable: displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || Variable: force || Quantity Type : Force || Location : Element || Tensor Type : Vector || Is Extensive : True || Data Type : Real || |+-----------------------------------------------------------------------------+| || Participant: Static Structural || Type : MAPDL || UpdateControls: || Option : ProgramControlled || Region: Fluid Solid Interface || Topology : Surface || Input Variables : Force, Force_Density || Output Variables : Incremental_Displacement || Variable: Force || Quantity Type : Force || Location : Node || Tensor Type : Vector || Is Extensive : True || Data Type : Real || Variable: Incremental_Displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || |+=============================================================================+| Analysis Control |+=============================================================================+| || Analysis Type : Steady || Global Stabilization : None || OptimizeIfOneWay : False || AllowSimultaneousUpdate : False || PartitioningAlgorithm : SharedAllocateMachines || |+=============================================================================+| Coupling Interfaces (1) |+=============================================================================+| || Interface: interface-1 || Side: One || Coupling Participant : Static Structural || Region List : Fluid Solid Interface || Reference Frame : GlobalReferenceFrame || Side: Two || Coupling Participant : Fluid Flow (Fluent) || Region List : fluid-solid_interface || Reference Frame : GlobalReferenceFrame || Data Transfer: Data Transfer || Suppress : False || Target Side : Two || Source Variable : Incremental_Displacement || Target Variable : displacement || Unmapped Value Option : Nearest Value || Mapping Type : Surface Profile Preserving || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Data Transfer: Data Transfer 2 || Suppress : False || Target Side : One || Source Variable : force || Target Variable : Force || Mapping Type : Surface Conservative || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Mapping Control: || Absolute Gap Tolerance : 0.0 [m] || Face Alignment : ProgramControlled || Poor Intersection Threshold : 5.00e-01 || Relative Gap Tolerance : 1.00e+00 || Stop If Poor Intersection : True || |+=============================================================================+| Solution Control |+=============================================================================+| || Duration Option : NumberOfSteps || Maximum Iterations : 2 || Minimum Iterations : 1 || Number Of Steps : 80 || |+=============================================================================+| Output Control |+=============================================================================+| || Output Control Option : LastStep || Results || IncludeInstances : ProgramControlled || Option : Off || Write Initial Snapshot : True || |+=============================================================================++-----------------------------------------------------------------------------+| Warnings were found during data model validation. |+-----------------------------------------------------------------------------+| Warning: Participant Static Structural (CouplingParticipant:Solution) has || the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. || Warning: Participant Fluid Flow (Fluent) (CouplingParticipant:Solution 1) || has the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. |+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent || participants are set to 'Element'. Make sure that this is consistent with || the setup within Fluent. When importing the SCI file (this includes running || inside Workbench), you can control the locations of these variables by || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more || information, refer to System Coupling User's Guide. |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...+-----------------------------------------------------------------------------+| "System coupling solution stopped before all participants connected. A || solver failure occurred during the run in the Fluid Flow (Fluent) system" |+-----------------------------------------------------------------------------+Transcript output stopped: 2023-03-20 18:03:01==============================================================================================================================================================Transcript output started: 2023-03-20 18:04:07===============================================================================+=============================================================================+| || Summary of Coupling Setup || |+=============================================================================+===============================================================================+=============================================================================+| Coupling Participants (2) |+=============================================================================+| || Participant: Fluid Flow (Fluent) || Type : FLUENT || UpdateControls: || Option : ProgramControlled || Region: fluid-solid_interface || Topology : Surface || Input Variables : displacement || Output Variables : force || Variable: displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || Variable: force || Quantity Type : Force || Location : Element || Tensor Type : Vector || Is Extensive : True || Data Type : Real || |+-----------------------------------------------------------------------------+| || Participant: Static Structural || Type : MAPDL || UpdateControls: || Option : ProgramControlled || Region: System Coupling Region || Topology : Surface || Input Variables : Force, Force_Density || Output Variables : Incremental_Displacement || Variable: Force || Quantity Type : Force || Location : Node || Tensor Type : Vector || Is Extensive : True || Data Type : Real || Variable: Incremental_Displacement || Quantity Type : Incremental Displacement || Location : Node || Tensor Type : Vector || Is Extensive : False || Data Type : Real || |+=============================================================================+| Analysis Control |+=============================================================================+| || Analysis Type : Steady || Global Stabilization : None || OptimizeIfOneWay : False || AllowSimultaneousUpdate : False || PartitioningAlgorithm : SharedAllocateMachines || |+=============================================================================+| Coupling Interfaces (1) |+=============================================================================+| || Interface: interface-1 || Side: One || Coupling Participant : Fluid Flow (Fluent) || Region List : fluid-solid_interface || Reference Frame : GlobalReferenceFrame || Side: Two || Coupling Participant : Static Structural || Region List : System Coupling Region || Reference Frame : GlobalReferenceFrame || Data Transfer: Data Transfer || Suppress : False || Target Side : Two || Source Variable : force || Target Variable : Force || Mapping Type : Surface Conservative || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Data Transfer: Data Transfer 2 || Suppress : False || Target Side : One || Source Variable : Incremental_Displacement || Target Variable : displacement || Unmapped Value Option : Nearest Value || Mapping Type : Surface Profile Preserving || Convergence Target : 1.00E-02 || Ramping Option : None || Relaxation Factor : 1.00E+00 || Mapping Control: || Absolute Gap Tolerance : 0.0 [m] || Face Alignment : ProgramControlled || Poor Intersection Threshold : 5.00e-01 || Relative Gap Tolerance : 1.00e+00 || Stop If Poor Intersection : True || |+=============================================================================+| Solution Control |+=============================================================================+| || Duration Option : NumberOfSteps || Maximum Iterations : 2 || Minimum Iterations : 1 || Number Of Steps : 80 || |+=============================================================================+| Output Control |+=============================================================================+| || Output Control Option : LastStep || Results || IncludeInstances : ProgramControlled || Option : Off || Write Initial Snapshot : True || |+=============================================================================++-----------------------------------------------------------------------------+| Warnings were found during data model validation. |+-----------------------------------------------------------------------------+| Warning: Participant Static Structural (CouplingParticipant:Solution) has || the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. || Warning: Participant Fluid Flow (Fluent) (CouplingParticipant:Solution 1) || has the ExecutionControl 'Option' set to 'ExternallyManaged'. System || Coupling will not control the startup/shutdown behavior of this || participant. |+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+| The variable locations of force and heatflow variables for all Fluent || participants are set to 'Element'. Make sure that this is consistent with || the setup within Fluent. When importing the SCI file (this includes running || inside Workbench), you can control the locations of these variables by || using the 'SYC_FLUENT_CONSNODAL' environment variable. For more || information, refer to System Coupling User's Guide. |+-----------------------------------------------------------------------------+Awaiting connections from coupling participants...+-----------------------------------------------------------------------------+| "System coupling solution stopped before all participants connected. A || solver failure occurred during the run in the Fluid Flow (Fluent) system" |+-----------------------------------------------------------------------------+Transcript output stopped: 2023-03-20 18:04:27===============================================================================
| Type : FLUENT |
| UpdateControls: |
| Data Type : Real |
| Variable: force |
| Data Type : Real |
| Type : MAPDL |
| UpdateControls: |
| Variable: Force |
| Data Type : Real |
| Data Type : Real |
| Analysis Control |
| Side: One |
| Side: Two |
| Suppress : False |
| Target Side : Two |
| Suppress : False |
| Target Side : One |
| Mapping Control: |
| Solution Control |
| Output Control |
| Results |
| Option : Off |
| participant. |
| participant. |
| Type : FLUENT |
| UpdateControls: |
| Data Type : Real |
| Variable: force |
| Data Type : Real |
| Type : MAPDL |
| UpdateControls: |
| Variable: Force |
| Data Type : Real |
| Data Type : Real |
| Analysis Control |
| Side: One |
| Side: Two |
| Suppress : False |
| Target Side : Two |
| Suppress : False |
| Target Side : One |
| Mapping Control: |
| Solution Control |
| Output Control |
| Results |
| Option : Off |
| participant. |
| participant. |
| Type : FLUENT |
| UpdateControls: |
| Data Type : Real |
| Variable: force |
| Data Type : Real |
| Type : MAPDL |
| UpdateControls: |
| Variable: Force |
| Data Type : Real |
| Data Type : Real |
| Analysis Control |
| Side: One |
| Side: Two |
| Suppress : False |
| Target Side : Two |
| Suppress : False |
| Target Side : One |
| Mapping Control: |
| Solution Control |
| Output Control |
| Results |
| Option : Off |
| participant. |
| participant. |
March 30, 2023 at 9:11 am
RM
Ansys EmployeeHi,
From error message in system coupling logs, it is observed that issue is with Fluent setup. Please have a look at the Fluent Transcript file (.trn) to identify the cause of the issue and make necessary changes in Fluent setup.I recommend going over this tutorial in the Ansys documentation that shows a 2-way FSI simulation with Fluent and Mechanical to understand the system coupling workflow. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sysc_tut/sysc_tut_reedvalve_fluent.html
5340
3325
2471
