October 8, 2023 at 7:52 am
Abdullah Hassan
SubscriberHi,
I am having an issue in ANSYS simulation. I am trying to do condensation of water vapor to water liquid but when I initialize the solution, it says latent heat cannot be less than zero.
I tried to search online & it comes to my knowledge that it is related to enthalpy.
as enthalpy of liquid is -2.858e+08 and
enthalpy for vapor is -2.418e+08 at standard temperature. so change in enthalpy is coming negative which means the latent heat is less than zero.
Can anyone help me, how to resolve this issue or what values I need to choose for enthalpies in this case.
NOTE: I already did the simulation for water boiling/evaporation and I didn't face such issue in that particular case.
October 9, 2023 at 9:02 am
Forum ModeratorIf you're using the Evaporation/Condensation model the To and From phase matters. I always have to check the manual, but if you currently have the vapour in the To field switch that to the From field.
October 18, 2023 at 9:25 am
Abdullah Hassan
SubscriberI understand that, what I am trying to do is Condensation of water vapor at 100 C,
for this case
From phase should be "from vapor'
to phase should be like " to liquid".
when I did this, it said latent heat can not be less than zero.
but when I do the opposite
from = liquid
to = vapor
system doesn't shows any warning. Infact it also did the condensation upon putting water vapor at inlet volume fraction as 1.
I don't understand that. can you please help
October 18, 2023 at 11:52 am
Forum ModeratorIt's because Fluent doesn't know which material is gas and which is liquid. All Fluent does is look at the material data and then add/remove energy based on the formation enthalpy. To get around this, the To and From phase definitions matter: hence my comment about checking.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
