Discovery Import
Discovery Import
Error license
    • rg
      Hi
      When starting spaceclaim from this error.
      Already performed all the procedures (access to all firewall ports - ping ok - run as administrator)
      I tried to uninstall all previous verisons and restart the system, disable the firewall: none of this seems to have any effect.
      The same behavior is found on two PCs with similar hardware and the same OS (Windows 7 x64).
      How can I solve?
    • Subashni Ravichandran
      Hi  Roberto
      Do you have a proxy server in place? If so, can you please refer this page and make the necessary changes.
    • rg
      Thank you
    • rg
      How do you set up the environment variable:
                        ANSYSLS_CLIENT_DISABLE_FNO_PING=1   ?
      • rg
        Roberto Subashni
      Hello  Roberto
      Please follow this path for environment variables:
      Control Panel → System and Security → System → Advanced system settings → Environment variables.
    • rg
      Hi Subashni
      I tried this test but now it gives me another error.
    • rg
      After the following error I tried to deactivate the license , even so it always releases the error.
      After I gave all access to the firewall, the anti-virus check is disabled to the anys folder but it still does not work.
      I have tested the ping and it does not show any data loss
      How can I solve the problem?
    • rg
      I tried to connect to a portable PC connected to the corporate wireless network "GUEST" (it is a weakened network but with different configuration, and that is not passing through a proxy).
      In this way, license activation is fine on the first attempt. It is also activated on the online ANSYS account.
      The laptop has the same antivirus installed then and to be definitively excluded that it is the cause.
      At this point it is necessary to understand which procedures should be performed or which ports must be opened on the proxy to allow even the workstations connected to the fixed domain network to activate the product.
    • rg
      Brian
      Hi  Roberto
      Please refer to this link on Proxy Server Configuration . Please let us know if applying these changes solve your problem
    • rg
      Hi subashni
      Come already said before I have already done this, but it does not work
    • rg
      After following the guide you told me, I started making other mistakes that I have described to you.
      Are there any other solutions?
      Regards
      Hi  Roberto
      Could you please send the files mentioned in the Troubleshooting document to Ansys Discovery Team . I will consult the developers and follow up with you via email.
    • rg
      Hi Subashni
      In the end, the client deactivated all the proxy servers in the devices where he installed spacecliam to solve the problem.
      Thank you for the help you gave me
      Regards
Viewing 13 reply threads
