Discovery Import
Discovery Import
error license
    • ufficiotecnico
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      * Rebuilt URL to: https://ansys-fno.flexnetoperations.com/
      *   Trying 64.14.29.39...
      * TCP_NODELAY set
      * Connected to ansys-fno.flexnetoperations.com (64.14.29.39) port 443 (#0)
      * ALPN, offering h2
      * ALPN, offering http/1.1
      * Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
      * successfully set certificate verify locations:
      *   CAfile: C:tmpca-bundle.crt
        CApath: none
      * TLSv1.2 (OUT), TLS header, Certificate Status (22):
      * TLSv1.2 (OUT), TLS handshake, Client hello (1):
      * TLSv1.2 (IN), TLS handshake, Server hello (2):
      * TLSv1.2 (IN), TLS handshake, Certificate (11):
      * TLSv1.2 (IN), TLS handshake, Server finished (14):
      * TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
      * TLSv1.2 (OUT), TLS change cipher, Client hello (1):
      * TLSv1.2 (OUT), TLS handshake, Finished (20):
      * TLSv1.2 (IN), TLS change cipher, Client hello (1):
      * TLSv1.2 (IN), TLS handshake, Finished (20):
      * SSL connection using TLSv1.2 / AES256-SHA256
      * ALPN, server accepted to use http/1.1
      * Server certificate:
      *  subject: C=US; ST=IL; L=Itasca; O=Flexera Software LLC; OU=Prod IT; CN=*.flexnetoperations.com
      *  start date: Jan  4 00:00:00 2018 GMT
      *  expire date: Jan  9 12:00:00 2020 GMT
      *  subjectAltName: host "ansys-fno.flexnetoperations.com" matched cert's "*.flexnetoperations.com"
      *  issuer: C=US; O=DigiCert Inc; CN=DigiCert SHA2 Secure Server CA
      *  SSL certificate verify ok.
      > GET / HTTP/1.1
      > Host: ansys-fno.flexnetoperations.com
      > User-Agent: curl/7.53.1
      > Accept: */*
      < HTTP/1.1 403 Forbidden
      < Date: Wed, 04 Jul 2018 12:59:20 GMT
      < Server: Apache
      < Content-Length: 21
      < Content-Type: text/html; charset=iso-8859-1
      < Set-Cookie: NSC_10.100.1.39_GOPXFC_443=14b5a3d94e3ccba681f7b2ff48ee03d4bb9c24581b8369761478e63378ce464c06e23611;path=/;secure;httponly
      Error 403 - Forbidden* Connection #0 to host ansys-fno.flexnetoperations.com left intact
      C:tmp>
    • Naresh Patre
      Hello  Alfa Inox Thanks for sending the details. I am looking into it and will get back to you.
    • rg
      Hi Naresh,
      thank you we hope to understand what is the cause to solve
      Regards
    • sander
      what was the fix? i've the same error in my curl output.
    • Naresh Patre
      suggested manual activation through command prompt
Viewing 4 reply threads
