Discovery Import
Discovery Import
Error – licensing
    • l.janicek
      Hello, our customer has issue with licensing.
      If he uses licensing (for example refresh all entitlement) via Command prompt, CMD gets back error bellow (when I used standard login, I saw only FNE error). Ping is OK, a tried to unblock firewall....
      Could you help me with the error?
      I tried to find the error on the forum, but without success. I found similar error with the certificate (https://discoveryforum.ansys.com/t/h4gzdg/fne-activation-failed-peer-certificate-cannot-be-authenticated-with-given-ca-certificates), but this error is about proxy name.
      C:Program FilesANSYS IncShared FilesLicensingwinx64>ansysls_client.exe -Ref
      reshLicenseEntitlements
      2020/05/27 09:15:50    NEW_CONNECTION      Connected to local subscription handl
      er: 62249@127.0.0.1
      2020/05/27 09:15:50    CLIENT_CONNECT
                                                      1/2/3/3   ::
                                                           1480
      2020/05/27 09:15:57    DENIED
                                                      1/2/3/3   ::
                                                           1480
                      FNE Update Entitlements Failed: FlexNet Embedded Action: FNE Gen
      erate Binary Request->FNE Send Binary Message
                      FlexNet Embedded error: [1,7e1,8,0[74000008,5,110001f3]] Generic
       communications error.
                      [1,7e1,8,0[75000001,5,30010255]] General data transfer failure.
      Couldn't resolve proxy name
      ERROR: Unable to refresh license entitlements on this device, error:
      FNE Update Entitlements Failed: FlexNet Embedded Action: FNE Generate Binary Req
      FlexNet Embedded error: [1,7e1,8,0[74000008,5,110001f3]] Generic communications
      error.
      [1,7e1,8,0[75000001,5,30010255]] General data transfer failure. Couldn't resolve
       proxy name
      Thnak you, Lukas
    • Naresh Patre
      Hello Lukas
      Looking at the error message about proxy name, it appears that the user has proxy server in place. Can you make changes in the proxy server settings as listed in section 5A and 5B of below mentioned troubleshooting document?
       Discovery License Activation Troubleshooting
      If the issue persists, please send all the files as listed in section 6 of the above mentioned document.
      • l.janicek
        Hi Naresh Patre
        everything is OK, now. We used the way - reinstall the windows from WIN7 to WIN10.
        Thank you, Lukas
    • l.janicek
      Hi Naresh, I will try and let you know.
      Thank you, Lukas
