December 2, 2022 at 12:37 pm
Martin Veis
SubscriberHello,
Using the FDTD solver, after I run a simulation and want to run the post-processing analysis, a "please wait" window starts flashing. It slows the calculation.
This happens if I run any analysis in any simulation files.
Videos:https://www.dropbox.com/s/ozcf7vjkhss3q5d/LumericalError.mp4?dl=0
https://www.dropbox.com/s/4zmcv3n6edo5us2/LumericalError2.mp4?dl=0
Platform: Windows 11
Lumerical R2.4
Setup: ASUS VivoBook Pro M7600QC-OLED037W R9-5900HX / 16GB / 1TB SSD / RTX 3050 / 16'' WQUXGA / OLED / 2r Pick-Up&Return / Win11 Home -
December 6, 2022 at 11:51 pm
Lito Yap
Ansys Employee@Martin Veis,
Can you try and download 1 or 2 examples from the Lumerical Application Gallery (Apps)? Let me know which examples you tried and if the issues persists with the examples so we can investigate and try to reproduce the issue. Thank you.
- Error on Lumerical device
2524
2066
1279
1096
457
