December 28, 2020 at 8:52 am
kim
SubscriberMy Customer has a problem as shown in attached picture. When SpaceClaim started, The error massage is displayed. I tried two things to fix this problems like below. 1. deleting the elements in the directory "C:Users
AppDataLocalSpaceClaim" 2. Inactive 'STL Pre' in SpaceClaim Option. (this check box has already turned off) However, the above attempt cannot change anything. They have Discovery Ultimate License to use The Discovery AIM Legacy. (2020 R1) There are no problems when AIM is start. Only for SpaceClaim. Could you please help us to avoid getting this error massage when starting the SpaceClaim ? Thanks Best Regards, -
December 28, 2020 at 10:10 am
Subashni Ravichandran
Ansys EmployeeHello jwkim Can you please share the diagnostic files as mentioned in this post to ansys-discovery-suppoer@ansys.com? -
December 30, 2020 at 11:03 am
Thank you for sharing the files. Let me check with my team on this.
Could you please let me know if you are using the latest version of the license manager? -
December 31, 2020 at 12:05 am
kim
SubscriberSubashni
The Latest version of the license manager is 2020 R1.
Thanks.
January 20, 2021 at 1:45 am
kim
SubscriberSubashni
Is there another solution to solve this problem?
January 21, 2021 at 2:33 pm
Can you please confirm that you have unzipped all the files before performing the installation?
If not, can you please try and re-install after unzipping all the installation files?
April 12, 2021 at 5:17 am
victoriacooper512
SubscriberHello jwkim
Please check if there is any junk files in your system
3744
2573
1793
1236
594
