November 15, 2023 at 7:29 pm
November 16, 2023 at 11:31 am
Saumadeep
Ansys EmployeeHi,
Clicking on the "Show 7 Messages" option should show you the messages. But if that is not the case, try resetting the App Data:
Follow the steps below to reset ANSYS Appdata:
- Exit ANSYS, if you are using it currently.
- Go to Start > Run
- Enter %APPDATA%
- A folder explorer window will open
- Open the Ansys folder. Look for the Ansys version you are using, for example, v221, and rename it to v221_Old
- Launch ANSYS and refresh the project
Saumadeep
- A solver pivot warning or error has been detected
8754
4658
3151
1678
1456
