Ansys Free Student Software
error message
    • labolatory
      Sometimes when I am doing the analysis, the error message "Failed in handling Fluent message." appears and the analysis stops. Why?
      More information will help, ie what is Fluent doing (saving, plotting etc) and are you doing anything else on your computer?
    • labolatory
      Ansys fluent is doing transient calculation. The time step is 0.05 and the number of time steps is 36000. I also try to export the result as a text file every 20 time steps.
      Is it failing at the point it's writing or during iterations?
    • labolatory
      yes
      Yes, both or yes, one or the other?
      Note, if the answer is "yes" again please read the definition of smart alec!   The UK version uses a slightly different term for alec.....
Viewing 5 reply threads
