Discovery Import
Discovery Import
Error message: AfdCore Controller
    • peter.akelly
      In Discovery AIM I am getting an error Message as per the attached file - I can see any reference to this in the Heklp or on the Forum - any advice as to what I need to do to avoid this message?
    • Naresh Patre
      Hello Peter,
      In the Message window, can you click on the drop down arrow located on the left of the message "Flow requires attention" which will display additional details about the problem. Can you send the snapshot of this message as well as the snapshot of the Flow panel located on left side of the application?
    • peter.akelly
      Well I seem to be hitting a variety of issues and cant make much progress at all and attach a variety of the error messages being reported. I have tried a re-install, but just about any attempt to run any fluids pre-built example or create one from scratch results in these sort of message being reported.
    • Naresh Patre
      The problem seems to be associated when connected to VPN. AIM cannot run with any template using the fluids solver on vpn. Exiting the VPN and rebooting the machine solves the problem. A defect DE172676 for a similar issue has already been submitted.
Viewing 3 reply threads
