Ansys Products
Ansys Products
Error Message in HFSS
    • GOLAP KANTI DEY
      I am running a simulation in HFSS and getting an error message what stops my simulation and the message is -Accurate transparency rendering is disabled to avoid slow rendering performance..
      I am running a system with windows 11 pro and having 32GB RAM
      What can I do now? Please help
    • Anchal Singh
      Hello Golap,
      The last message in the Message Manager window, which you are considering an error, is not actually an error. It is just information and it doesn't affect your simulation. I can see your simulation has been completed normally (Normal completion of simulation on server), so don't worry about anything and proceed ahead.
      Thanks,
      Best regards,
      Anchal
    • GOLAP KANTI DEY
      Thank you for your reply.
      But when such message comes simulation dont run further.
      For your information this is not the case all time. Sometimes when I run simulation I am getting such message and simulation get stopped.
      Could you know why it happens and how to solve the problem.
    • Anchal Singh
      Hello Golap,
      Please check the convergence and simulation profile of the model after getting these messages. Also, try to plot the simulation results.
      From the picture, you posted, it is quite clear that your simulation has been completed normally.
      Please provide more information about convergence, simulation profile, etc. if you are unable to plot the simulation results.
      Thanks
      Best Regards
      Anchal
Viewing 3 reply threads
