Error message in Messing
    • Sushil Sharma
      I am trying to generate mess in my wind turbine blade but each time i got error message on messing( In scrrenshot shows). Does anyone has any idea about it, how can i solve the problem.
      Given the cell size on the hub connector I suspect you don't have sufficient resolution to produce an acceptable mesh. Click on Help and have a look at the tutorials.
    • Sushil Sharma
      What is the meaning of ( Your product license has numerical problem size limit, you have exceeded these problem size limits and the solver cannot proceed) message. I have student version and want to solve the above mentioned model. Is it due to student version?
      Student has a cell count cap as it's intended for learning rather than running large models, posted here https://www.ansys.com/academic/students/ansys-student . Research and Commercial keys don't have a limit, so you're capped by hardware and time.
Viewing 3 reply threads
