Error Message: The solver engine was unable to converge on a solution for the nonlinear problem as c
    • bibas
    • Cheta Rathod
      Can you please share solve.out file and images showing the model Boundary Conditions?
    • bibas
      n
    • bibas
      Should i put any other images?nI want to apply pressure in the two spars at the same time to see the deformation in the wing spar in the center that later will be inserted a fracture on, but it only runs one pressure at a time...n
Viewing 3 reply threads
