May 16, 2023 at 9:11 am
Tim Dietl
Subscriber -
May 16, 2023 at 11:31 am
SubscriberHello Tim,
Even when the contact appears closed, if the size of the Initial substep is too large, the moving part can pass through the contact and give you that error.
Increase the number of Initial Substeps by a factor of 100 and try to solve again. If you get the same error add another step to the number of steps and change the load applied in Step 1 to 1% of the original load, then Step 2 can be the original load. This works if the load is a force or pressure but not if the load was Standard Earth Gravity. In the later case, you have to replace Standard Earth Gravity with Acceleration so you can apply 1% of 9.8 m/s^2 in Step 1.
May 17, 2023 at 6:16 am
Tim Dietl
Subscriber -
May 17, 2023 at 6:23 am
Tim Dietl
SubscriberOf course, the mesh will be changed to a better mesh. But for now the calculation time is more important until I find the problem.
May 17, 2023 at 6:46 am
May 17, 2023 at 8:58 am
Tim Dietl
SubscriberProblem fixed, it was a SpaceClaim Bug with the Shared Tool. Thank you for your help as always!
3251
2443
