Error: non-character element in list_to_string Error Object: p
    • shoji
      I'm using Fluent in batch mode and MATLAB by using AAS. When MATLAB send below command,
    • DrAmine
      I do not have much experience with that connection: but can you check if the TUI command really works in your case by just typing it in Fluent.n
    • shoji
      When I try it in serial mode, It works without the error. But When I try in parallel mode, The error occurs.nDo you have any ideas about this ?.Thanks.n
    • DrAmine
      No. Have you tried typing the command directly in Fluent?n
    • shoji
      Yes I tried it and the error didn't occur.nDo I have to meke a UDF for parallel mode ? nhttps://www.learncax.com/knowledge-base/blog/by-category/cfd/parallelization-of-udfs-in-ansys-fluent#:~:text=When%20you%20run%20a%20UDF,the%20'n'%20node%20processes.n nMy simplified UDF is bellow.nn#includeudf.hn#includedynamesh_tools.hn#includen#includenDEFINE_CG_MOTION(pitch_ccw, dt, vel, omega, time, dtime)n{ntomega[2] = -M_PI * 10000 / 1800;n}nnThanks.n
      No idea, there's a chapter in the manual that covers what is and isn't parallel. n
Viewing 5 reply threads
