December 7, 2020 at 1:09 pm
Aaron_123456
SubscriberThe above error message occurred relating to engineering data component whilst running mesh convergence study using parameters. nIt appeared to be the result of a single design point, I have since removed all parameters from 15 systems and the error remains. nThe individual systems solve for user input mesh parameters ie; edge length, but fail to solve using the parameter/ design point screen.nnThanks in advance -
December 14, 2020 at 8:45 pm
Gary Stofan
Ansys EmployeeThe message is generic in that the object failed to mesh or failed to solve etc.nIt may be that the project is corrupt in some way.nOpen Mechanical, then File - Export - .mechdat. nStart a New WB projectnDrag the .mechdat onto the project whitespace.nEnter your Design Points etc. nSave and try the solve again.
- A solver pivot warning or error has been detected
8700
4658
3151
1672
1446
