Ansys Products
Ansys Products
Error on fluent in Ubuntu 20.04 LTS
    • mehdi Abbas
      I am getting this error after I try to open fluent on ubuntu
      "Host spawning Node 0 on machine"
    • George Karnos
      This is not an error. this is a message stating that the program is launching on the machine.
      If it does not proceed, first thing I would look at is the prerequisites.
      Make sure ALL are installed.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/installation/unix_platform_libraries.html
      As well as:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/installation/unix_platform_add_det.html
      Is there more information in the console window? right-click in console window and then choose
      select all. once highlighted, right-click again and choose copy. Then paste the info here.
      EXAMPLE:
                    Welcome to ANSYS Fluent 2022 R2
                    Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
                    Unauthorized use, distribution or duplication is prohibited.
                    This product is subject to U.S. laws governing export and re-export.
                    For full Legal Notice, see documentation.
      Build Time: May 27 2022 08:52:29 EDT  Build Id: 10212
      Connected License Server List: 1055@SERVER1
      Host spawning Node 0 on machine "SERVER1" (win64).
      ID    Hostname  Core  O.S.         PID    Vendor
      n3    SERVER1   4/24  Windows-x64  13020  Intel(R) Xeon(R) Gold 6136
      n2    SERVER1   3/24  Windows-x64  30512  Intel(R) Xeon(R) Gold 6136
      n1    SERVER1   2/24  Windows-x64  23876  Intel(R) Xeon(R) Gold 6136
      n0*   SERVER1   1/24  Windows-x64  14568  Intel(R) Xeon(R) Gold 6136
      host  SERVER1         Windows-x64  588    Intel(R) Xeon(R) Gold 6136
      MPI Option Selected: intel
      Selected system interconnect: default
      Cleanup script file is C:\Users\user1\cleanup-fluent-SERVER1-588.bat
      Loading "C:\Users\user1/.fluent"
      /file/read-macros "C:/Program Files/ANSYS Inc/v212/Rocky/fluent/udfs/rocky_fluent_coupling.scm"Loading "C:/Program Files/ANSYS Inc/v212/Rocky/fluent/udfs/rocky_fluent_coupling.scm"
      ...Rocky-Fluent Coupling Module is not available for the current Fluent release version!
      Done.
      Done.
    • Mangesh Bhide
      Hello
      try these settings in Fluent launcher
      in fluent Launcher click on more options >> then go to parallel settings tab >> under mpi types select openmpi
      or if using command line then add “-mpi=openmpi” without the quotes to the command line
      hope this helps
