Photonics
Photonics
Error on Lumerical device
    • Raikage97
      Running the following code:
    • Khashayar Ghaffari
      Hi We are not allowed to download attachments on the forum. The error could be related to different factors such as incorrect simulation settings or the problem itself being difficult to converge. I recommend looking into this convergence troubleshooting article that describes some of the adjustments in the advanced settings that could resolve convergence issues. Additionally, like you mentioned having a well-adjusted mesh across the simulation region can be important; more specifically, that the mesh is able to resolve the smallest features of the simulation while allowing for larger mesh size in other areas, to reduce total simulation time. I also suggest examining your voltage boundary condition settings. For example, itÔÇÖs recommended to start the simulation from 0V to avoid potential initialization convergence errors.
    • Raikage97
      I'm going to try what you said. Thanks!
