August 30, 2022 at 5:17 am
August 30, 2022 at 5:24 am
ivanandadonny
SubscriberAs it seen on the console,theres an error message appears exactly after running the calculation (No. of iteration has been set to 500). But the results are exceeding the example from video. it stop after 177th Calculation,then the error message come up after. Is there any solution for that?
Thank you in advance.
August 31, 2022 at 4:08 am
najmamiftach
SubscriberI encountered the same problem where instead of converging, the residual just oscillates infinitely. I tried looking up solutions to this but still hasn't found any definitive answer. Please let me know if found some kind of answer to why this is happening
September 6, 2022 at 11:13 am
henry.hoang
SubscriberHi ivanandadonny
This error might happen due to uncompatible physics models or wrongly compiled UDFs. Could you please check if you have any UDFs in your simulation?
Henry
September 13, 2022 at 4:07 am
najmamiftach
SubscriberHello Henry, thank you for your suggestion. What do you mean by UDF and how can I check that?
- can’t login to cloud acccess using the same email on the independent campus web
- Selamat Datang
- Rosette Gauge Purpose
- Web Course Ansys
- Brake Pad Analysis Simulation Problem
- Cell Phone Drop Test Simulation Problem
- lumbar motions simulations problem- in solid mechanic
- Lumbar Motion Simulation – Coding part
- Meshing Problem in Helicopter Pitch Arm
- Could anyone have solution to fix it? Thanks
2656
2120
1345
1118
461
