Error opening Ensight .case files after multiple restarts with smaller timesteps
    • SHerrera
      Hi all.
      I'm running System Coupling on a Linux-Based HPC. I've been restarting my cases with smaller timesteps each time but recently I have found I can't open either results.case file due to the following error. This problem only occurs in some cases, others open normally.
      Has someone encountered this and found a solution?
      Connection accepted.
      This is EnSight Server 2021 R2 (5/25/2021) build: 5288b459f release-21.2
      Running on computer: , , pid: 31192
      USERD_reader_close
       Using environmental variable TMPDIR
      --> TMPDIR = /scratch/7506554
      Log Detected 12 CPU core(s), 6 maximum parallel threads.
      ##ERROR OCCURS AFTER THIS. ABOVE OUTPUT IS NORMAL.
      Found 2 Casefiles using 'scan' method specified in the .mcf file.
      Error ERROR: Error> {s1:1} verify_increasing_times() in timesets.c:601
           of EnSight Server 2021 R2:
      Error ERROR: Error sequencing data.
      Error ERROR: Descending/duplicate ordered time values: t[219:218]={0.3,0.3}
      Error ERROR:
      Error ERROR: Error> {s1:1} readensight_casefile() in resu.c:1283
      Error ERROR: initializing time-set spans using case data format
      Error ERROR:
      UDW Info: server has 5 UDWs.
      Error loading parts. Please check console window for details.
    • Murari Iyengar
      Hi
      This error occurs when you stop/restart a transient simulation and the .encas files get overwritten. In some instances, the .encas file gets modified and does not have all the timestep files/data included in it. It can also occur when you transfer the files midway through a calculation from one location to another and some of the timestep data gets lost along the way. As good practice, I recommend creating a new file for each simulation and avoiding changing the file location midway through the simulation.
