Error: Operation would result in illegal T surface bodies
    • Panos_Ai
      Hello, I am trying to create a solid body like in the figure 1.
    • Govindan Nagappan
      Arraynextrude each semi-circular region separatelynThat is, extrude the curves highlighted in the image separately. Repeat this for each regionnOnce you create separate solids, you can select all the solids in the tree, right click and select form new part to connect the bodies using shared topologynSee if this helpsnn
    • Govindan Nagappan
      ArraynOr see if you can create surface from sketch. Then select and extrude 3 faces . Select faces that do not share vertexnExamplen
