Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Error: ‘Process “dtds” terminated abnormally’
    • KANTUBHUKTA HEMANTH HARI KISHORE
      Greetings to all,
             I'm Hari Kishore; while simulating and running my modal in ANSYS maxwell, I'm encountering with errors such as "Process 'dtds' terminated abnormally" or "Process 'G3dMesher' terminated abnormally".
      My modal consists of a middle closed coil and a tube of 100mm length, and two end coils (connected in series) placed above and below the tube. Why these errors are coming and how to rectify them. Please clarify me.
      Thank you.
    • HDLI
      Hello Hari,
             I suppose it is meshing issue. Could you modify resolution of curved surface meshing (move it right or left) in initial mesh setting? and then enable "Use dynamic surface resolution" too. Thanks.
      HD
      Hello HD,
               I modified the resolution of curved surface meshing and enabled "Use dynamic surface resolution".
               Now I'm getting another error "Process 'G3dMesher' terminated abnormally".
               And I tried changing the mesh element values from 1000 elements to 3000 elements or 500 elements, which resulted in the same error.
               Could you please guide me through these errors.
       Thank You.
