October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeWhat is the cause of error: Radiation element has negative or zero temperature?
October 17, 2017 at 9:51 am
Arun
Ansys EmployeeDefine the substeps for proper radiation calculation otherwise you may get negative values. Also, specify an initial temperature for the model around the expected temperature so the solution starts farther from zero. Make sure an offset temperature has been defined (TOFFST).
2116
1343
1118
461
