June 21, 2022 at 10:06 am
ridoykarmoker1815
SubscriberI am doing a project on ansys aqwa for hydrodynamic diffraction and at the time of getting graph, its showing error reading form plt file, error code -1 in error window. What should i do???
June 29, 2022 at 2:11 pm
Mike Pettit
Ansys EmployeeHello, please follow the instructions in this thread: https://forum.ansys.com/forums/topic/plt-file-when-using-workbench-aqwa/ Mike
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3740
2570
1785
1236
594
