Error reading user defined results
    • Paulvh
      Hello everyone,
      For a project I'm working on, I would like to read certain user defined results, e.g. EPPL1. However if I create any user defined result from the solution worksheet and try to evaluate the results, I get the following script error:
    • Aniket
      Unfortunately, Ansys staff can not download files on the forum, so can't download the dump file that you have uploaded, but can you try to check this on another simpler model to see if it is project-specific? (or on another model to see if it is machine-specific?)nAlso, try resetting the AppData in the following way:nclose all workbench sessionsnopen %appdata%/Ansys (assuming that you are using windows)nrename v195 to v195_old (assuming that you are using 2019R3)nand recheck if the same behavior is seen in the project.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
    • Paulvh
      Unfortunately, Ansys staff can not download files on the forum, so can't download the dump file that you have uploaded, but can you try to check this on another simpler model to see if it is project-specific? (or on another model to see if it is machine-specific?)Also, try resetting the AppData in the following way:close all workbench sessionsopen %appdata%/Ansys (assuming that you are using windows)rename v195 to v195_old (assuming that you are using 2019R3)and recheck if the same behavior is seen in the project.-AniketHow to access Ansys help linksGuidelines for Posting on Ansys Learning Forumhttps://forum.ansys.com/discussion/comment/105105#Comment_105105
      Hi Aniket,nI tested in a newly generated simple project: it works as it should, no problems. Then I tested again in my current project: the problem persists. It seems the problem is project specific then.nI tested my current project after resetting the AppData as described. Again, the problem persists. nAny ideas?n
