error: Received signal SIGSEGV
    • giovanni_ianziti
      Hello!
      Someone can help me with this error in ansys fluent? How can I solve this? I`m working with ansys 19.2
      Node 0: Process 2532: Received signal SIGSEGV.
      Node 1: Process 4508: Received signal SIGSEGV.
      Node 2: Process 15656: Received signal SIGSEGV.
      Node 4: Process 14380: Received signal SIGSEGV.
      Node 5: Process 14500: Received signal SIGSEGV.
      Node 6: Process 10872: Received signal SIGSEGV.
      Node 3: Process 8280: Received signal SIGSEGV.
      MPI Application rank 0 exited before MPI_Finalize() with status 2
      The fl process could not be started.
      SIGSEV tends to be network related, but may be triggered by something else in the solver: it's not an error we can diagnose as such. What did the TUI show just above all of that lot? That text may be more useful.
    • Keyur Kanade
      Please provide more information.
      Are you getting this error while opening fluent or doing iterations?
      Are you able to launch fluent separately?
      Can you please a simple test case to check if fluent can be launched.
    • giovanni_ianziti
      I`ve this problem when I use a UDF and I initialize the simulation.
      • ahmed ibrahim
        i have the same problem, do you solve it?
      What does the UDF do (or rather what is it supposed to do)?
    • giovanni_ianziti
      I`m trying to simulate mass and energy transfer during evaporation-condensation (from water to vapour)
      Does the model work if the UDF is off?
    • Keyur Kanade
      Can you please use inbuilt functions for evaporation and condensation instead of udf?
    • giovanni_ianziti
      yes, the model work without the UDF.
    • Keyur Kanade
      Then it may be udf. As ANSYS employee, we dont debug users udf. So you may need to debug it on your own.
      Given that work through the UDF and see what data is needed where, and then check that it's available. Whilst staff can't debug UDFs the community can, so feel free to post the code and people can comment/advise.
    • smovagh
      I have the same problem. Have you fixed your error?
    • smovagh
      I have the same problem. I am also using serial processing since we don't have parallel processing license for our fluent academic license. may this error relate to our license?
      I have 3 UDF files for the source terms and it is for evaporation model. After compiling successfully, I faced this error while I ran the case;
      Node 0: Process 24144: Received signal SIGSEGV
       If the UDF compiles that means the code is grammatically correct: it doesn't mean the code is suitable for Fluent. Check the model works without the UDF, then turn them on one at a time.
    • jianan.zhao
      Hello all,
      I want to track particles in laminar airflow through rat airway. All the UDFs I hook works well but the "on_demand" one.
      would you please let me if you hae had the same experience?
      When I execute the "on_demand" UDF, I face this error:
      Node= 999999:
      Pro
      cess =======944
      =========4: ===========
      Node 12: Process 9676: Received signal SIRe
      ceivedGSEGV.
      Nodesignal SI
      GS======================================================EGV
      Nod===========e =====================================================================================
      Node 0: Pr=====================================================================================
      Node 5: Process 9388: Received signal SIGSEGV.
      ======================11: Process 10=====ocess ===10440========================================: Receiv==148: Re=====
      ed signal ========ceived signal SIGSEGV.
      Node 2: Process 10360: Received signal SIGSEGV.
      SIGSEGV.
      Node ===================================================================
      Node 3: Process 10152: Received signal SIGSEGV.
      Node 4: Process 8080: Received signal SIGSEGV.
      ==============13: Process 8420: Received signal SIGSEGV.
      Node 1: Process 8892: Received signal SIGSEGV.
      Node 8: Process 10728: Received signal S============================
      Node 14: Process 8628: 10: Process 9852: Received signal SIGSEGV.
      =======================================================IGSEGV.
      Node 7: Process 5064: Received signal SIGSEGV.
      Node =================9: Process===== 596Received signal SIGSEGV.
      4: Received signal SIGSEG=====================================
      V.
      You're better off starting a new thread: please do this and I'll lock this one.
      • ahmed ibrahim
        please, did the problem solved yet?
      I am studying melting of nano enhanced pcm in 2d cocenrric geometry and desity if pcm is dependent upon temperature so i had made udf for all property but when i define density or specific heat as user defined this error comes
    • Mahadev Pande
      Just run fluent and workbench as administrator (change compatabillity settings to save yourself the trouble) , reset the workbench from setup onwards ie. reset the setup and see if that solves the issue.
Viewing 17 reply threads
