March 25, 2021 at 5:16 am
dhruvdeshwal17
SubscriberGreetings
This is an error I am facing while doing analysis.
The analysis - A copper plate and a magnet are placed adjacent to each other with a certain gap. A velocity is given to the plate (-0.1m/s) and the magnet remains stationary. So, as the plate move, the plate will see a change in a magnetic field by which eddy current will be generated in the plate and due to this current a magnetic field will be generated of opposite polarity as that of the magnet. Due to this generated magnetic field, the magnet experiences a force. I FMAGBC the copper plate and parallel flux as a boundary condition.
My aim is to calculate the eddy current, Lorentz force associated with this analysis, but I am not able to solve it.
Please provide any suggestion regarding loading, model, or anything you like to suggests
I am providing Marcos of my problem for a better understanding of the analysis.
/PREP7
ET,1,SOLID97
KEYOPT,1,1,1
KEYOPT,1,2,1
KEYOPT,1,5,1
KEYOPT,1,1,1
!Real Constants
R,1,
RMORE, , , , ,-0.1, ,
RMORE, , , , , ,
R,2,
RMORE, , , , , , ,
RMORE, , , , , ,
! Material Properties
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1.2289 ! Permeability of magnet
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MGXX,1,,
MPDATA,MGYY,1,,
MPDATA,MGZZ,1,,9.26e5 !coercive force of magnet
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,0.999 ! Permeability of copper plate
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,2,,1.72e-8 ! Resistivity of copper plate
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,3,,1 ! Permeability of air
! Modelling
BLOCK,-0.013,0.013,-0.013,0.013,-0.0025,0.0025, ! copper plate
CYLIND,0.013, ,0.0055,0.0355,0,360, ! magnet
BLOCK,-0.05,0.05,-0.05,0.05,-0.05,0.05, ! enclosed area
FLST,2,3,6,ORDE,2
FITEM,2,1
FITEM,2,-3
VOVLAP,P51X
FLST,2,3,6,ORDE,3
FITEM,2,1
FITEM,2,-2
FITEM,2,4
VGLUE,P51X
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
NUMCMP,VOLU
! Meshing
TYPE, 1
MAT, 1
REAL, 2
ESYS, 0
SECNUM,
MSHAPE,1,3D
MSHKEY,0
CM,_Y,VOLU
VSEL, , , , 2
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
TYPE, 1
MAT, 2
REAL, 1
ESYS, 0
SECNUM,
CM,_Y,VOLU
VSEL, , , , 1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
TYPE, 1
MAT, 3
REAL, 2
ESYS, 0
SECNUM,
CM,_Y,VOLU
VSEL, , , , 3
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
ALLSEL,ALL
! Force Flag
VSEL,S, , , 1
ESLV,S
CM,A,ELEM
ALLSEL,ALL
FMAGBC,'A'
! Boundary Condition
FLST,2,6,5,ORDE,2
FITEM,2,11
FITEM,2,-16
DA,P51X,ASYM
FINISH
/SOL
! Tranisent Velocity
ANTYPE,4
TRNOPT,FULL
DELTIM,0.002,0,0
OUTRES,ERASE
OUTRES,ALL,ALL
AUTOTS,1
TIME,0.01
/STATUS,SOLU
SOLVE
Thank You!
March 25, 2021 at 1:14 pmNavya C
Ansys EmployeenWhich Ansys tool are you using for this simulation?.RegardsnNavya?nMarch 25, 2021 at 1:41 pmdhruvdeshwal17
SubscriberHellonANSYS APDL 16.0 (Academic Research)nRegardsnMarch 26, 2021 at 8:52 amErik Kostson
Ansys EmployeeThis element is no longer supported - use current elements like solid226.nSee example for more info:nhelp/ans_lof/lof2Dstatmaganalexamples.html#d0e5425nIn low-freq. emag chapter:nn2.5.3. Example: 2-D Static Magnetic Analysis with Velocity EffectsnnHope this helpsnnEriknnMarch 26, 2021 at 9:43 amdhruvdeshwal17
SubscriberThank You!nViewing 4 reply threads- You must be logged in to reply to this topic.
2656
2120
1345
1118
461
