December 11, 2022 at 8:50 am
December 12, 2022 at 5:17 pm
Guilin Sun
Ansys EmployeePlease right click on the red text to get detailed error message. Is this for CHARGE, HEAT or DGTD?
It might be due to curved surface on a planar surface, or every thin and long layers. You can reduce the mesh quality and use smaller override mesh locally.
You may also need to install the latest version.
- Error on Lumerical device
2564
2078
1293
1106
459
