error running on Linux
    • soloviev
      I am having an issue running a model on an HPC linux cluster. I have run similar models fine, and this is a new issue. It runs for a few autosaves, then I get the following error:
      error removing /home/bv169/simulations/fw_lens_cluster/2km_large_sal_diff_50m_deep/OCE7533121fluent.53416/lnamd64/3ddp_node/.nfs00000011800002670000001b
      terminate called after throwing an instance of 'std::runtime_error'
        what():  NodeCell::addFace : Size exceeded
      I have tried deleting the folder which the error is specifying (since it says its having trouble removing) and I changed the permissions of the folder to allow editing, reading, and writing by all users and computers. None of these issues solved the problem.
      I'd appreciate any feedback.
      Thanks,
      Alex
    • soloviev
      As an update, I have tried deleting the folder, changing the permissions again, and making sure the model is running on the same nodes as it was originally. I still am receiving the error. This is also in the error file: Node 113: Process 400842: Received signal SIGBUS.
      I'd appreciate any suggestions.
      Thanks,
      Alex
