October 11, 2018 at 9:29 am
anilwakale
Subscriberdear all,
I got following error and my simulation stops
Node 999999: Process9270: Received signal SIGSEGV
is anyone got this type error in Ansys fluent v16.2 when used in the parallel processor
When I search for the error it shows data collection error through multiple processors
how can we transfer all the data through MPI on the Main node where we can write all the data in fluent v16.2
October 11, 2018 at 4:09 pm
Ansys EmployeeIt's possibly a network glitch, are you running over several machines?
October 11, 2018 at 4:19 pm
anilwakale
SubscriberI am using a single workstation
And once I switch my simulation to the series mode it works fine but it takes a lot of time to complete one simulation
October 12, 2018 at 4:12 am
anilwakale
SubscriberHello rwoolhou,
The problem got solved with the Ansys fluent v18 I don't know how but I just thought to upgrade Ansys version and try. It got solved
Simulations were running fine
Thank you
October 12, 2018 at 4:26 am
harigkumar
SubscriberAre you using UDF's? Fluent tends to give this error if the UDF is not parallelized correctly.
October 12, 2018 at 4:31 am
DrAmine
Ansys EmployeeThanks for the update. Please highlight that the topic has been resolved and mark the and mark the answer of rwoolhou as the answer.
2688
2138
1349
1136
462
