November 7, 2018 at 9:14 am
November 7, 2018 at 10:05 am
Ansys EmployeeCan you check you have write permissions and enough disc space? If it's a network (or USB) drive try saving locally too as saving files over the network can be problematic.
November 7, 2018 at 12:57 pm
fa-ri
SubscriberThank you for your response.
what does writing permission mean?
I checked the disc space and it was enough.
I don't use USB or network drive.
I tried another disk to saving file but I got the error again.
November 7, 2018 at 2:52 pm
Ansys EmployeeWrite permissions are that you can actually save files onto that area of the disc. For example IT may lock down certain folders to stop users breaking things. Please check the scratch folder (Workbench -> Tools -> Options) space too.
Have you saved the project before?
November 12, 2018 at 6:27 am
Keyur Kanade
Ansys EmployeePlease go to the folder where you are writting the files. Then try to create a new folder or file in that folder. If you have write permissions, it would allow to create it.
2630
2104
1327
1110
461
