August 13, 2019 at 5:20 pm
SkyLeopard
SubscriberHi,
I am trying to set up my student version of Ansys. I have run into the issue that my spaceclaim does not exist/is not active it seems.
A quick browse of the forum lead me to this thread:
https://forum.ansys.com/forums/topic/spaceclaim-not-active-in-my-ansys-19-2/
I followed up to the point they stopped responding. It did not have a solution.
I went into %appdata% and into my SpaceClaim folder.
There is no 19.2 Folder (or 19.4 I think that is the version I have)
There is no SCDM19.2 folder (or 19.4)
The only file I see in this location is giprof.out
I attached a screengrab.
Install package is:
ANSYSACADEMICSTUDENT_2019R2_WINX64
The directory I have it installed in is:
C:Program FilesANSYS IncANSYS Studentv194
August 14, 2019 at 6:08 pm
tsiriaks
Ansys EmployeeHi SkyLeopard,
Can you launch stand-alone SpaceClaim ? Open CMD Prompt, then copy paste the following command
"C:Program FilesANSYS Incv194SCDMSpaceClaim.exe"
Please also post the screenshot of the error message about Spaceclaim.core.dll
Thanks,
Win
August 14, 2019 at 6:24 pm
SkyLeopard
SubscriberHi Win,
I was unable to enter that into the command prompt. I had to cd into Ansys Student. There didnt seem to be a direct path from ANSYS Inc to v194 using your
I got there in the command prompt using:
"C:Program FilesANSYS IncANSYS Student/v194/SCDM"
Upon entering SpaceClaim.exe I got what is in attached image 1.
Error message (upon opening) screenshot is image 2.
Just the error message is image 3.
Screenshots of files (that i think are relevant) in SCDM are images 4&5
1)
2)
3)
August 14, 2019 at 9:31 pm
tsiriaks
Ansys EmployeeWhoops , sorry I provided the wrong path, I forgot this is ANSYS Student.
Yea, you were right to go to C:Program FilesANSYS IncANSYS Studentv194SCDM
the main issue here is that you don't have SpaceClaim.exe for some reason even though you have a bunch of other files.
I would recommend to uninstall this and make sure to completely remove C:Program FilesANSYS Inc folder before reinstalling it.
Now, make sure you turn off all security software like Firewall or Anti-virus, etc. Then reinstall the software with 'run as administrator'
Once finished, check if you have C:Program FilesANSYS IncANSYS Studentv194SCDMspaceclaim.exe
Thanks,
Win
August 15, 2019 at 2:21 pm
SkyLeopard
SubscriberHi I have reinstalled it as admin.
I checked the file path. It looks like spaceclaim is there this time. However on start up I get the error: unable to connect to or start local server
The installer said it completed install with errors. I am also attaching the error log i found
I am having trouble uploading images at the moment I will come back and try later
August 15, 2019 at 3:35 pm
SkyLeopard
SubscriberI installed it again. It seems I missed a folder when deleting on my last install. I just opened a project and so far everything seems to be working.
August 15, 2019 at 4:59 pm
tsiriaks
Ansys EmployeeThat's great to hear !
If you are all set, please mark this thread as 'resolved' ('Is Solution') so we know this thread has been addressed.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2508
2064
1277
1088
456
