Error transfering results to CFD Post
    • karamat10
      Hi there!!!
      I got an error when transferring results from fluent to CFD-Post.
    • DrAmine
      Does it happen for other projects? Can you open the results in CFD-Post Standalone (not in the Workbench)?
    • karamat10
      Nope,
      It is not working for one project.
      I have created the same project for the second time but no progress.
      Check, and if any other ANSYS products are open close them. Then try again.
      Another alternative is to drag another Results component onto the Solution cell and try to open that (in case the workflow is corrupted).
      Finally, export the Fluent case & data from the Solution cell and open CFD Post in standalone mode (as Amine suggests).
    • karamat10
      Problem started when i first opened CFD for a project last night. Now when i open ansys from desktop  the above error prompts.
      Should i reinstall ANSYS?
    • DrAmine
       Rename %AppData%Ansysv1xx and try start CFD-Post outside of WB. If still not working then reinstall the most actual release with explicit admin rights (RMB and run as administrator). The same applies for uninstall (as admin).
    • karamat10
      Thank you for kind suggestions.
      When i opened the project from archive (Wbpz) format. It transferred the results to CFD.
      Regards
      (Karamat Ali)
    • DrAmine
      That means the old project was corrupt.
      Please mark the problem as solved. Thanks.
Viewing 7 reply threads
