July 23, 2018 at 9:14 pm
jarrett.wise
SubscriberHello,
I have been running a simulation with 559,995 elements and 782,941 nodes. The simulation has been running and recently it has started crashing with the error on , and all of a sudden it shows up with the error on "Your product license has numerical problem size limits, you have exceeded these problem size limits and the solver cannot proceed."
I have tried refreshing the geometry and clearing the results data, but the error keeps coming up all of a sudden.
I am using the university research license with ANSYS 17.0.
Does anyone have any suggestions?
July 23, 2018 at 9:55 pm
SubscriberHello Jarrett,
It sounds like an ANSYS Student license was installed at some point on that computer. You can't have both a Research license and a Student license on the same machine. Uninstall any ANSYS Student license if you can. If that doesn't work, there are various house cleaning operations to do before you reinstall ANSYS 17.0
Peter -
July 23, 2018 at 10:03 pm
jarrett.wise
SubscriberThank you for the quick reply Peter. The licenses for ANSYS are on a server for the university. I haven't had this problem before, but I didn't know if this could happen since IT recently acquired a newer license and put it on the server? Attached is a screenshot of the license manager.
Thanks again for the response,
Jarrett
July 24, 2018 at 12:49 am
I see that you have one Research license and one Academic Teaching license for Mechanical and CFD.
What happened to you is that the Research license was in use when you opened your model and tried to solve. ANSYS checked out the Academic Teaching license, which does have a Node and Element limit, and that is the error you got.
Next time you want to solve the big mesh, first check the status of the license by going to All Programs > ANSYS 17.0 > ANSYS Client Licensing > Clent ANSLIC_ADMIN Utility 17.0
When that program opens, select View Status > View the License Status. There will be a list of all the licenses and whether they are in use or not. For example you might see:
Users of ansys: (Total of 1 license issued; Total of 0 licenses in use)
or
Users of ansys: (Total of 1 license issued; Total of 1 licenses in use)
followed by the userid and computer name that is using that license.
Cheers,
July 24, 2018 at 5:15 pm
jarrett.wise
SubscriberThanks Peter. That helps a lot.
I have one last question of a problem I am having with this simulation. I am using the element birth and death technique. Is there a code to add to APDL when turning the selected elements back on such that they are strain free? I have an initial stress with them in the alive command, but the resulting stress pattern is slightly off and we believe it is due to the strain in the elements from being removed and then added back in next to elements that already have a stress pattern.
Thanks for your expertise.
Thanks,
Jarrett
July 24, 2018 at 5:28 pm
SubscriberHi Jarrett,
I don't have a lot of experience with element birth and death and the alive command. Copy and paste that paragraph into a new discussion in the Structural Mechanics section.
One more point to add to the license issue above is once you open Mechanical, the license it checked out is included in the title bar of the window. That is an easy way to confirm that you didn't get the Academic Teaching license.
Cheers,
- Error trying to solve with research license
- Fluent parametric sweep from workbench getting stuck
- ANSYS Electronics Desktop 2019 R2 and the new update of windows 10
- Facing issues with Microsoft MPI in ANSYS EDT HFSS 2020R2
- Getting error of “waiting for license server to respond”
- Trying to solve model in Lsdyna extension but cannot get the workbench lsdyna on toolbar as shown.
- Issue while opening ANSYS Additive print 2020 R2 app
- 2021 R1 student version, mapdl is not launching
- Troubleshooting 2020 R2 Student
- ANSYS Discovery file is undeletable
2752
2156
1365
1150
462
