March 25, 2021 at 3:19 pm
marcin.lelit
SubscriberI use recent version of Lumerical Suite on Windows. When running training simulation set up accordingly to FDTD100 tutorial video, simulation crashes at approx. 15%, with an error: "Process number 0 unable to locate checkpoint file." Can anyone point me to the solution of the problem? Log file attached.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2706
2142
1355
1144
462
