November 9, 2023 at 1:35 pm
Jordi Lopez Leyva
SubscriberI ran a 3D FDTD simulation in Lumerical on HPC Linux. This simulation seems to work fine, giving all the results I want. However, in the shell window, I get told "unexpected end of file". What is this error, how can I solve this and do I need to solve this?
6.64173% complete. Elapsed simulation time: 6.64173e-15 secs. Max time remaining: 8 secs. Auto Shutoff: 1
15.4974% complete. Elapsed simulation time: 1.54974e-14 secs. Max time remaining: 7 secs. Auto Shutoff: 1
33.2087% complete. Elapsed simulation time: 3.32087e-14 secs. Max time remaining: 6 secs. Auto Shutoff: 1
50.9199% complete. Elapsed simulation time: 5.09199e-14 secs. Max time remaining: 4 secs. Auto Shutoff: 1
68.6312% complete. Elapsed simulation time: 6.86312e-14 secs. Max time remaining: 3 secs. Auto Shutoff: 1
86.3425% complete. Elapsed simulation time: 8.63425e-14 secs. Max time remaining: 1 secs. Auto Shutoff: 0.311047
100% complete. Elapsed simulation time: 1.00041e-13 secs. Max time remaining: 0 secs. Auto Shutoff: 0.264385
sh: switchml: line 1: syntax error: unexpected end of file
sh: error importing function definition for `BASH_FUNC_switchml'
sh: _module_raw: line 2: syntax error: unexpected end of file
sh: error importing function definition for `BASH_FUNC__module_raw'
sh: error importing function definition for `BASH_FUNC__module_raw' -
November 14, 2023 at 8:18 pm
Lito Yap
Ansys Employee@Jordi Lopez Leyva,
Sorry to hear that you are having issues running FDTD on your cluster. To troubleshoot, please assist us with the following:
- Which Linux distro and version are you running on?
- Which version of Ansys Lumerical are you using?
- Do you run/submit to a job scheduler using a script?
- Does the simulation run successfully?
You can check the "simulationfilename_p0.log" file if the simulation is completed. - Can you open the simulation on your local desktop to view the results?
- Are you using the bundled MPICH2 to run the simulation?
- Please send the sample execution line you used to run the simulation on the cluster.
e.g. /opt/lumerical/v232/mpich2/nemesis/bin/mpiexec -n 32 /opt/lumerical/v232/bin/fdtd-engine-mpich2nem -t 1 simulationfile.fsp
Thanks!
November 15, 2023 at 10:10 am
Jordi Lopez Leyva
Subscriber- Which Linux distro and version are you running on?
- CentOS Linux release 7.9.2009 (Core)
- Ansys Lumerical 2023 R1.1
- No script, just command
You can check the “simulationfilename_p0.log” file if the simulation is completed.- Simulation did complete succesfully
- Yes
- I’m indeed using the bundled MPICH2 from the Lumerical installation
- /cm/shared/apps/lumerical/2023-R1.1/mpich2/nemesis/bin/mpiexec -n 4 -host tue-login002 -env HOME /home/”MyPath”/Lumerical/test /cm/shared/apps/lumerical/2023-R1.1/bin/fdtd-engine-mpich2nem -t 1 /home/”MyPath”/Lumerical/test/Nanobeam.fsp
November 15, 2023 at 8:18 pm
Lito Yap
From the command you provided,
/.../mpiexec -n 4 -host tue-login002 -env HOME /.../test /.../fdtd-engine-mpich2nem -t 1 /.../Nanobeam.fsp
Are you running the simulation remotely from a Linux machine to another Linux machine, 'tue-login002' ?
Are you able to log in to the Linux machine, 'tue-login002', and run it directly from there (not remotely)?
i.e.
/cm/shared/apps/lumerical/2023-R1.1/mpich2/nemesis/bin/mpiexec -n 4 /cm/shared/apps/lumerical/2023-R1.1/bin/fdtd-engine-mpich2nem -t 1 /home/”MyPath”/Lumerical/test/Nanobeam.fspOtherwise, try the command below, without the '-env HOME' options for the MPI. Let me know if the issue persists even though the simulation ran successfully.
/cm/shared/apps/lumerical/2023-R1.1/mpich2/nemesis/bin/mpiexec -n 4 -host tue-login002 /cm/shared/apps/lumerical/2023-R1.1/bin/fdtd-engine-mpich2nem -t 1 /home/”MyPath”/Lumerical/test/Nanobeam.fsp
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1680
1470
