Platform
Platform
Error updating parametric points
    • samsatch
      Hello guys, I am using the parametric study in workbench, and i am having this weird error, it keeps updating on point and ignoring another, when I update the points manually there's no problem, but when I select all and update it does it, the message error is :"(DP 4) Failed to update Results component in for calculation point : Error when updating Results cell in system for calculation point 4." , or something like that, i translated (english is not the default language in Ansys).
      I joined a picture bellow.
      Thanks
    • Aniket
      Can you please set the DP11 or any other DP that is failing and manually check the solver output and solution in Mechanical?
      -Aniket
