January 23, 2023 at 10:43 am
Ben_Ben
SubscriberI posted the error previously but I have been waiting for a reply since Decemeber 9th.
Please see post here: https://forum.ansys.com/forums/topic/runaway-velocity-error-using-dynain-file-for-sequential-simulations-with-beams/
I will repost the main issue here:
I simplified my sim down to one beam but the second simulation does not behave as expected. I have outlined my test scenario below, all analysis settings are the same etc.
In my first sim I applied a displacement inwards towards centre at each end
Here are the results
In the second simulation I applied the same displacements but towards the outside.
But I get ridiculous results, here are the results on non-deformed geometry and deformed geometry
Please could advise on if I can run this scenario with a restart analysis. Where I can change my boundary conditions.
Thanks,Ben
January 26, 2023 at 1:11 pm
Ram Gopisetti
Ansys EmployeeHi Ben, what version of ANSYS are you using, have you tried to open dynain file in prepost?, how does it look, did you tried to load via external data method?
cheers, Ram
January 27, 2023 at 11:03 am
Ben_Ben
SubscriberHi Ram,
I'm using Ansys2022R2. Trying dynain in LS-PrePost now.
Thanks for reply,Ben
January 26, 2023 at 6:57 pm
Reno Genest
Ansys EmployeeHello Ben,
Could you do this in one simulation without the dynain? Why do you need to do this in 2 steps an 2 simulations?
If you do it in one simulation, you need to specify different times for the displacement BCs moving in and out.
Let me know how it goes.
Reno.
January 27, 2023 at 11:13 am
Ben_Ben
SubscriberHi Reno,
The example problem I'm sharing here is a simplification of my actual modelling scenario. I get the exact same issues with my full model. I will describe it below so you can better understand.
My modelling problem involves two steps. It consists of several helical beams (like the one in my picture).
1. I displace the top node of beams in the x-direction. The bottom nodes are free.
2. Then I displace the top node and bottom nodes toward the centre. Effectively compressing the helical beams.I can't do in one simulation because I need bottom nodes free in first step and then a displacement BC in the second step.
Many thanks for your reply,Ben
January 27, 2023 at 11:29 am
January 26, 2023 at 7:01 pm
Reno Genest
Also, what process do you use with the dynain file in WB? Can you show a screenshot of your WB project schematic?
Reno.
January 28, 2023 at 12:47 am
Reno Genest
You could do that in one simulation with *BOUNDARY_SPC and *BOUNDARY_PRESCRIBED_MOTION using the BIRTH/DEATH options to activate and deactivate the BCs at specific times. Have look at the user manual for more information on these keywords:
https://lsdyna.ansys.com/manuals/
If you are a commercial customer, please submit a service request on the Ansys Customer Portal:
support.ansys.com
We will be able to get your model and troubleshoot it. Ansys employees are not allowed to upload and download models in this forum.
Reno.
January 30, 2023 at 9:07 am
Ben_Ben
SubscriberHi Reno,
Would I need to do this in LS-PrePost? Rather than LS-Dyna Workbench?
Thanks,Ben
January 30, 2023 at 12:06 pm
Ben_Ben
SubscriberHi Reno,
I used 3 *BOUNDARY_PRESCRIBED_MOTION
First one - Displacement on Top Node (Bottom Node Free)
Second one - Compression on top node
Third one - Compression on bottom node
Is this what you hd in mind with birth and death times. I use 0-0.005 for the displacement of Top and then 0.005-0.01 for compression of bottom and top nodes.
I haven't used *BOUNDARY_SPC. Do I need to if my bottom node is free in all DOF.
Thanks for your suggestion Reno,
Ben
January 30, 2023 at 6:54 pm
January 30, 2023 at 6:57 pm
Reno Genest
Yes, this is what I had in mind with birth and death. *BOUNDARY_SPC is used to fix degrees of freedom (DOFs) for some nodes in your model. You can have fixed or free DOFs. You can achieve the same with *BOUNDARY_PRESCRIBED_MOTION and settting the displacement to zero (fixed).
Reno.
January 31, 2023 at 11:28 am
Ben_Ben
SubscriberHey Reno,
It worked for my test model. Am running my full model now. Thanks for your input!
Ben
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2656
2120
1347
1118
461
