November 20, 2018 at 9:12 am
Max4
SubscriberHi,
when I try to change a boundary type from "fluid" (inlet with velocity) to "wall" using Events, I have the following error.
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
Maxime
November 20, 2018 at 9:36 am
DrAmine
Ansys EmployeePlease check your setup: changing the BC is working for me. You can try executing a command if you struggle with the BC change.
November 20, 2018 at 9:37 am
seeta gunti
Ansys EmployeeFluid is a cell zone condition. You can use either Fluid or Solid where as inlet is a boundary condition. Please check the boundary conditions and edit it.
Seeta
November 20, 2018 at 9:42 am
Max4
SubscriberI have an inlet and an outlet with a moving piston.
Boundary Conditions : Inlet: Velocity
Outlet: Pressure
I want to close the outlet for a time t1 (Outlet to Wall) and then open it at a time t2. What should I use for Type when I want to change the Outlet from Wall to Outlet with pressure?
What do you mean by " Setup " ?
Maxime
November 20, 2018 at 10:04 am
Ansys EmployeeYou're looking for a pressure-outlet for the type in your post above.
The original error means you've missed a setting somewhere: ie the wall doesn't have a temperature on it or similar. You should still be able to work with the case so look through all of the panels for a missing input. If you have an injection what was that attached to?
November 20, 2018 at 10:15 am
November 20, 2018 at 10:33 am
Max4
SubscriberThank you for your answers. The simulation is still running, but a problem persists in the changing of the boundary type. What may I use (Type) to change the outlet from Wall to an outlet with a pressure?
" alt="" width="271" height="319">
Indeed, I have define at the beginning the outlet (pressure 0 Pa). At t=0s, it changes to Wall, and at t=0.033s, it should change from Wall to the oulet with pressure, which was define at the beginning.
Maxime
November 20, 2018 at 11:49 am
Ansys EmployeeHaving looked & checked with a colleague the Define Event method you're using won't work. If you want to switch to an inlet you'll need to use a TUI (text window) command in the event. That command will start with
/define/boundary .......................
Type that into the TUI and use Enter to show the available commands & q to move back up a level.
November 20, 2018 at 11:55 am
Max4
SubscriberI noticed this, and as a result I'm writing a Scheme file and then loading it to finally use with TUI Commands.
Thank you for taking the time to check this.
Maxime
2656
2120
1345
1118
461
