November 30, 2017 at 9:03 pm
koma0124
SubscriberHello Guys,
yesterday I installed the student version of ANSYS 18.2 on my system. I followed all steps for installation and finally startet Workbench. When showing up the project windows the following error came up: "An unknown operation requested." No more information was gives by the pop-up. After that the toolbox was empty and I wasn't able to do any calculation.
First I thought it could be a problem with my system: I've got Win10 Pro 64Bit on a SSD and installed ANSYS first on my HDD. After the error I tried installing ANSYS also on the SSD, but it did not work .After that I tried older Versions - 18.1 and 17.2 (last one using the system variables for licensing). But nothing of all worked, it always came the same error message.
Has anyone of you got this problem or has a tip for solving it? I actually got all three mentioned versions in my download folder, so "try and error" is easily and fast done... Would be great if someone can help me out with this.
Thanks a lot!
December 1, 2017 at 8:45 pm
Raef.Kobeissi
SubscriberHello, did you previously have an older version of ANSYS? if yes, did you make sure to delete all folders related to ANSYS? What GPU do you have? Is everything up to date(drivers) in your windows?
Cheers -
December 4, 2017 at 5:59 pm
koma0124
SubscriberHi,
no, it was the first time to install ANSYS. Even after testing the mentioned versions I deleted all files on my drive.
GPU I am using is the NVIDIA GeForce GTX 1050 TI, drivers seem to be up to date.
December 4, 2017 at 8:17 pm
Raef.Kobeissi
SubscriberHmm, a bit unusual because the installation files are working perfectly fine. -
November 15, 2020 at 4:47 am
niteshyerra
SubscriberHI, I installed ansys student 2020 R2 in my system and i get this error An unknown operation requested. and ther eis no toolbox for me. I cleared all the files in my system and reinstalled but i am not able to find the toolbox. I also tried resetting the workspace layout too. Can anyone help me. I am stucknn
- Workbench error
- Workbench not opening
- License Error
2656
2116
1337
1118
461
