March 15, 2022 at 10:02 pm
SebdB
SubscriberGood day!
I am currently designing a hybrid brushless exciter. At the moment the design is experiencing a high cogging torque. I am trying to mitigate this by making use of rotor skew. When I apply skew to the model (15deg), and proceed to analyse, I encounter an error saying that it cannot be analysed with an ECE in the external circuit, and should instead make use of an ECER.
I have searched the web, manuals, tutorials, lectures, YouTube, and alas - nothing has been of assistance.
The cogging torque can be seen below:
March 17, 2022 at 3:46 pmDELI
Ansys Employee, this feature is not available in current versions, and will be supported in 2022R2.
March 23, 2022 at 8:09 pmDELI
Ansys Employeecan you share the picture of MaxCir?
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2959
1449
1322
