Error when define new expression in CFD-Post
    • José Mantovani
      Hello friends!
      So, I make some simulations of BFS using RANS turbulence models. I want plot, for example, Cp vs x/h but, when I define the Cp expression I get this error above. What can be it? I think, the expression is setting in the correct way...
      If I set for example x/h like: X/(0,0098[m]), or other expression I get the same error, and in my look all everything stay correct...
      Someone Can help Me?
      Thanks for opportunity!
      Mantovani.
    • raul.raghav
      Mantovani, you should be using “.” instead of “,”
      For e.g. 0,5 is supposed to be 0.5
      1,225 [kg m^-3] is supposed to be 1.225 [kg m^-3]
    • José Mantovani
      It's true Rahul... Ansys use the american digit code, I'm from Brazil and here use other digit code... Now it's works well, but I have other doubt.
      When I plot, for example, in FLUENT, Cf vs xH in the line of wall it's work ok, but when I do it in CFD Post I get the error in image below, whats can be it?
    • raul.raghav
      Can you provide a screenshot of the expressions you defined for 'Cf Variable' and 'xH'? And can you also provide a screenshot of the 'lowerwall' and 'upperwall' polylines?
      For the chart definition, X-axis needs to be the 'wall' polyline and Y-axis needs to be the 'Cf Variable'.
Viewing 3 reply threads
