October 3, 2018 at 4:01 pm
meu22
SubscriberHi!
When trying to Get Results for Solve (using Structural Mechanics), I encounter this error message:
SGE cluster does not have parallel environment sge_pe_rr defined.
Submit Failed
Failure validating parallel environment sge_pe_rr
However, in the Solution Process tab of ANSYS 19.1 Workbench, I had already made the default execution mode parallel and altered it to match with sge_pe_rr. Any ideas on overcoming this issue?
October 4, 2018 at 12:57 pm
Sandeep Medikonda
Ansys EmployeeMoving to the system category and adding tags so that your post might get more traction
- Changing of font size
- System Coupling
- ANSYS Workbench Mechanical Solver problem after saving
- 3D ROM in workbench
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- ANSYS Direct Optimization
- HARDWARE COMPATIBILITY
- System Coupling
- When I open the Electronic Desktop, Twin Builder auto opens
2688
2138
1355
1140
462
