Error when importing Tecplot file (.plt)
    • Thodorisdm
      Dear,
      I want to average the flow field of my last 10 time steps and then import it back in Fluent.
      I am doing the averaging in Tecplot but whenever I am importing the .plt file into Ansys Fluent, I get the following error :
      Multicore SMT processors detected. Processor affinity set!
      Opening library "C:\PROGRA~1\ANSYSI~1\v201\fluent\fluent20.1.0\vki\win64\devtools4.4.6.dll"... done.
      MPI Application rank 0 exited before MPI_Finalize() with status -1
      The fl process could not be started.
      Can you help me with this?
      Kind regards,
      Binary or ASCII?  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_FileImport.html%23flu_ug_file_import_tecplot
      You do know about the Data Sampling in Fluent?
    • Thodorisdm
      It is binary.
      I know it but it cannot help me. I want to modify the flow field for the last ten time-steps, by caclculating the average of the previous time- step and the current and then replace the current flow field with the averaged.
      I can do it in Tecplot but the problem is when importing the (tecplot binary file --> .plt) back to fluent. I am using Fluent 2020R1 and I have tried tecplot versions from 2008 till 2019 but always the same error.
      Thank you.
      If you don't change anything does the file read into Fluent?
    • Thodorisdm
      I tried it but still the same error persists.
      What type of cells have you got, and did you do any adaption?
    • Thodorisdm
      Mainly structured and very few unstructured. I am using sliding mesh approach. When exporting the .plt file nothing changes on the mesh.
      I downloaded the 2023R1 version but still I get the same error.
      Let me describe the followed process in case the mistake is in it :
      1. Read the .cas.h5 file.
      2. Import the tecplot file at the same time step as the loaded case file.
    • Thodorisdm
      I don't think there is a solution to this issue.
      I will probably have to switch to PyFluent or Scheme scripting. Which one is more computationally efficient to handle large matrices?
      The Tecplot format (.plt) overwrites the mesh anyway so is just mesh and data, no boundary conditions: no need to read in the case. Have you tried deleting the non-conformal interface before writing the Tecplot file out?
      Depending on what data you need you may find Interpolation files easier to deal with. A colleague has used Python to merge data files before, he used legacy .dat but that was also before the HDF format was available.
    • Thodorisdm
      Thank you for your reply.
      I think working with the interpolation files is the way to go.
      However, in order to be more efficient, I want to use them in binary format. Therefore, could you please inform me on how are they encoded?
      If it's not in the manual I can't comment: the forum is classed as an Export so I must comply with US law.
Viewing 10 reply threads
